1500 solid axe swap
now im new to the forum world and i have no much clue how this hole process works , but i own a 06 1500 ram that currntelt has a 6inch procomp lift and 35s , i know that anything can be done but im very curiose on if anyone has done a sold axle swap with the 1500s in the 3rd jens , now i know it may seem pointless cause why not just buy a 2500 but i already own a 1500 and in the begging had no intentions on lifting it , but know the talbes have changed a bit , so does anyone know anything about this topic ? thank you
I have toyed with the idea of doing a SAS on my 08 dodge. But, for now I am controlling the urge. Here is a rough idea of what I will do eventually.
Axles - undecided at this point, don't know if i want to swap out just the front (older ford or dodge) or swap a whole set (newer ford/dodge 3/4 or 1 ton).
Suspension - somewhere around a 6-8 inch leaf spring lift from an older chevy or ford SD. With the added lift from the hanger and shackle, should tower over 38"
Frame - brace front crumple zone, and install a standard steering box, preferably 3/4 dodge style for compatibility.
Extras - standard stuff, shocks, adapt draglink to pitman arm, sway bar, new front drive shaft, etc.
Has been done by a few, don't know the specifics (what axle was used, etc.) but I know there was a LOT of fabrication which also means expense involved, unless you have a shop and can do it yourself...
yea i figured its been done before , but yeah your right about it being a lot of work i really made the mistake of buying a 1500 , no offense to anyone who has them i love the truck don't get me wrong , i also wonder how a 2500 doge axle would work , so many quesstions about it but not so many answers haha
Its been done before. The guy who built the truck in this artical has almost 6K in the SAS alone.
I was also toying with the idea the first time I took my 04 1500 offroading. Needless to say after replacing a CV joint and having the front end aligned the next day, I sold it after 3 months and bought a 2500. That is the cheapest SAS you can do...
I went from this, that I bought in November 08:
To this, That I bought in January 09:
Trending Topics
Unless your offroad more than on. The 1500 IFS is just fine. There's no need to do a SFA swap IMO. Especially since your from L.I. There's not much there.
Alphie had the right plan. Cheapest way is to trade or sell the 1500 for a 2500.
I am still waiting for the first time I destroy a CV. I've put mine through it's paces, to be sure, and so far so good.
I have been thinking about carrying a spare in the tool box though. Changing one out in the field is not all that hard, and I already carry the tools I would need...
