Hella 500 Question??????
Old May 6, 2009 | 03:48 PM
EJM05's Avatar
EJM05
Default Hella 500 Question??????
I was at Auto Zone today picking up some tar remover and all that good stuff. As I was walking up the isle I noticed the Hella 500's. I think they were going for like $74.99 for one. Does that sound right? What did you guys pay for yours? Also, on the box it said that it was a plug and play application. How easy is the install. Im considering buying them but I want to confirm all this stuff first. Thanks for the help.
Old May 6, 2009 | 03:55 PM
DodgeThunder's Avatar
DodgeThunder
I havent gotten my hellas yet but im planning on it.. check on ebay or amazon and you can usually get them cheaper.. and the install is pretty easy.. if youve ran offroad lights on a truck before then wiring these are the exact same as that.. Im not so sure about plug and play because the dodges dont have plugs in the stock harness anywhere to just clip the hellas in.. try the DIY section in the 3rd gen tech and theres probably some intsructions in there from someone who did it already..
Old May 6, 2009 | 03:58 PM
pavester's Avatar
pavester
i bought mine for under 40.
Old May 6, 2009 | 04:00 PM
EJM05's Avatar
EJM05
Alright thats what I thought. I knew that was to expensive. Ill look around for more. Oh, I have never weird a thing in my life. I new to all this stuff. I look for the DIY section.
Old May 6, 2009 | 04:01 PM
SilverBullet08's Avatar
SilverBullet08
39.99 on ebay with free shipping
Old May 6, 2009 | 04:13 PM
Bigc9164's Avatar
Bigc9164
$49 and they werent the easiest to instal but it wasnt bad.
Old May 6, 2009 | 04:20 PM
DodgeThunder
offroad lights are easy to wire.. power from battery through fuse to switch in dash to lights.. I dunno about hellas.. alot of lights ground through the base of the light.. If your planning on putting other offroad lights in a bull bar or light bar or anything else aftermarket electircal you can get aux fuse blocks that will hold 4, 5, 10 fuses.. whatever you like for a couple dollars.. that way you just screw it somewhere and run 1 power wire to it from the battery and then through the fuses to all your lights.. so you only have 1 wire coming off the battery instead of a big mess of wires..
Old May 6, 2009 | 04:26 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
They are an easy install, but not plug and play. It does take some wiring on your part.
Old May 6, 2009 | 05:53 PM
pavester's Avatar
pavester
teach, did you buy your hellas from dealmonger?
Old May 6, 2009 | 07:14 PM
04-fourseven's Avatar
04-fourseven
Easy to install, but not plug and play.
I bought mine from dealmonger for 39.99, free shipping. Ugraded wiring and bulbs.
dirtydog has a DIY in FAQ
