LED turn signal problem
Old May 8, 2009 | 11:23 AM
jackedupram02's Avatar
jackedupram02
Default LED turn signal problem
I just installed some led bulbs for the front turn signals, and i get a lamp out and they barely flash. I read up on this and found that installing a 6ohm 50watt resistor on each side works but the resistors gets hot (which i dont like). I checked online and found a LED turn signal relay, which replaces the stock relay. Has anyone ever used one of those and does it actually work?
Old May 8, 2009 | 04:52 PM
Matt99's Avatar
Matt99
if you are worried about the resistor getting hot there is a heat block you can put the resistor in, $1.00 at any radio shack. The resistor getting hot is not a problem, they do not get so hot as to melt anything? They are used in every LED application, one way or another...
Old May 8, 2009 | 05:34 PM
Alpheus's Avatar
Alpheus
You can use a higher watt resistor with a heat sink that will work also...
Old May 8, 2009 | 05:41 PM
Matt99's Avatar
Matt99
heat sink...thats what I meant, not heat block...thanks alph
