Front Driveshaft AWD Ram
Old May 11, 2009 | 01:12 PM
Markmm0000's Avatar
Markmm0000
Default Front Driveshaft AWD Ram
Hey guys. I took some pictures of my front driveshaft because I was planning on removing it for the summer. My truck is a 05 ram 1500 5.7. Can anyone tell me if it looks like the drive shaft holds the case fluid in there? If does im just gonna leave it. Also I took the pictures on my phone so there not the greatest.
Old May 11, 2009 | 01:18 PM
604's Avatar
604
it does hold some fluid i think..ive never taken one off but im pretty sure something would leak out..why do u wanna take it out for summer??
Old May 11, 2009 | 01:19 PM
dirtydog's Avatar
dirtydog
Moderate User
Anytime you have a yolk entering a housing, there will be a seal there which hold the fluid in! Guys do run them without the driveshaft, but will lose fluid and get dirt inside there as well as moisture.
On the one end, you could remove the u-joint and the yolk part will just stay there which seals it off. Not sure about the other end. i think it is an open style fitting??? Never had one off on a Dodge before.
