Transmission Temperature Gauge DIY
Old 05-12-2009, 11:50 PM
davb673's Avatar
davb673
davb673 is offline
Wow. Thanks silverbullet! I am looking to do this sometime, so I appreciate the DIY write-up...
  #22
Old 07-04-2009, 04:15 PM
buddahead's Avatar
buddahead
buddahead is offline
Thanks for the info. I put mine in the trans cooler line-I should have read this first, but...silly me . I would rather have put it in the trans itself. Anyways, I drove the truck around and realized it wasn't working. If you put the tee in the rubber line, you need to ground the tee to make it work.
  #23
Old 07-13-2009, 12:30 PM
moosefire66's Avatar
moosefire66
moosefire66 is offline
What year is your truck? I did a quick look under at my trans. and could not find this third port that you put the sensor in. I have a 2002 4.7 auto. I would assume it is the same, yes??
  #24
Old 07-13-2009, 12:43 PM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
mines an 05 with the 5 speed auto. the ports are on the right side of the trans
Quick Reply: Transmission Temperature Gauge DIY
