crank & tire size?
Old May 14, 2009 | 09:10 AM
dutter's Avatar
dutter
Default crank & tire size?
ok, i cranked my t-bars. my rear is sitting at 40" from ground to top of wheel well and the front is sitting at 39 1/4". im going for tires after work today. question: are the stock 265/70/17's gonna look to small? should i step up to 285's? (then i will need 5 tires. 1 for spare). just looking for some opinions.
Old May 14, 2009 | 11:02 AM
MarvOhio's Avatar
MarvOhio
i have 34" tall tires on mine with totally stock suspension setup.
Old May 14, 2009 | 11:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The numbers you are asking are width and Im running 305s on mine now with about the same measurements
Old May 14, 2009 | 11:19 AM
jonnymagnum's Avatar
jonnymagnum
I'm runnin 325/60-20 which is about 35x12.5 with T bars cranked.
Old May 14, 2009 | 11:21 AM
Alpheus's Avatar
Alpheus
https://dodgeforum.com/forum/3rd-gen...d-fitment.html
Old May 15, 2009 | 12:44 AM
rtom40's Avatar
rtom40
Default Tire size
I have a 04 2500 4x4 i am thinking of putting a 2" leveling on front I have 285/70/17 BFG tires now the problem aroung 70 miles an hr i get a slight vibration have anyone encountered this?
Old May 15, 2009 | 01:02 AM
Pyro's Avatar
Pyro
I Beat Tetris
Could be a number of things, most likely is that your spacers for the 2" of lift aren't installed quite right or your alignment is off.
Old May 18, 2009 | 01:29 PM
dutter's Avatar
dutter
Old May 18, 2009 | 01:33 PM
dutter's Avatar
dutter
try again
Old May 18, 2009 | 01:40 PM
dutter's Avatar
dutter
try again
try again
