Fabtech ....
Old May 20, 2009 | 07:57 PM
0threeHEMI's Avatar
0threeHEMI
Default Fabtech ....
I am currently installing my fabtech 6'' kit on my 03 1500 crew cab. Everything is going decent except i only have one leaf spring for the rear on each side? No blocks,? just the add a leaf? Is this correct. I guess i just dont see this being in sync with the front? Also what is the ride going to be like it seems like my shocks will top out? fabteh wasnt very helpful either when i called them this morning. any help would be great?
Old May 20, 2009 | 08:02 PM
AF_HEMI's Avatar
AF_HEMI
first off its a Quad Cab secondly, welcome to the forum. if your kit didnt come with longer shocks you'll definently need new shocks. I went with Fox Racing Nitrogen 2.0. They're amazing... cant talk enough about em. As for the leafs, to my knowledge thats all you need. You should see a substantial difference in size between the stock leaf and the new leaf. Fabtech is a good choice. You should be really happy with it. Ride is awesome, and even better off road (especially with a great set of shocks)
Old May 20, 2009 | 08:23 PM
santafehemi's Avatar
santafehemi
you will like the lift and the ride. the add a leaf should give you the right amount of lift as for the shocks yeah you will need longer shocks. my system came with new shocks for the rear and uses the factory set up for the front.
Old May 20, 2009 | 08:24 PM
0threeHEMI's Avatar
0threeHEMI
I got the fabtech performance shocks, how much more were the fox shocks? They were supposed to give me those but ended up sending me just the fabtech performance shocks? and never charged me for them, bummer!!!
Old May 20, 2009 | 08:29 PM
AF_HEMI's Avatar
AF_HEMI
you'll be fine with the fabtech performance ones...even better when they dont charge ya! the fox shocks are about $250 each.
Old May 20, 2009 | 08:39 PM
0threeHEMI's Avatar
0threeHEMI
Smile
Hmm do you have the fox shocks all the way around, or just in the back. I might just have to upgrade, do you have the specs on the shocks?
Old May 20, 2009 | 09:48 PM
AF_HEMI's Avatar
AF_HEMI
got em all 4's. 4wheelparts . com has the specs
Old May 20, 2009 | 09:55 PM
dazed01's Avatar
dazed01
Is the fabtech lift worth the money? I have an 08 4x4 1500 quad cab and am putting 35" km2's on it tomorrow and am now looking for a good lift
Old May 20, 2009 | 10:18 PM
Redone4x4's Avatar
Redone4x4
i have the 6" fabtech with the addaleaf. im not a big fan of the addaleaf, the front sits about 1/2" higher that the rear with no load. And the rear end just about comes off the ground over speedbumps. my plans are to remove it, block the rear, and install airbags to handle the weight/load better. just my opinion.....
Old May 21, 2009 | 12:58 AM
AF_HEMI's Avatar
AF_HEMI
from reviews I've read, fabtech is the best performing 6" lift out there. If you're only looking for looks, the fabtech is probably a little pricey
