Fog/High Beam Combo
Old May 20, 2009 | 08:55 PM
Matt99's Avatar
Matt99
Default Fog/High Beam Combo
Okay I know there is a jumper trick to make your headlights cut on while your high beams are on...Well, my fusebox doesnt show a headlight fuse...07 1500? Where would I put the jumper wire???
Old May 20, 2009 | 09:25 PM
NoBlinger's Avatar
NoBlinger
From what I have been able to find since I have an 07 too is that the wire jumper mod is a no go. You can however use a starscan tool to change the settings. I will try to find it for you.
Hee ya go.
Using Starscan tool:
1. Disable Fog light (COMPLETELY)
2. Re-enable fogs
a. It will ask which country, choose EXPORT
If you just try to change country code with out first disabling the fogs all together, nothing will happen.
PS If you don't know what a Starscan tool is it would be the scanner type thing the plug into you data port at the dealer. So you will need someone cool at the dealer to do it for you. I am still waiting to find that person. Any Techs in NJ hit me up!
Old May 20, 2009 | 10:02 PM
Matt99's Avatar
Matt99
Thats what I have heard also....that sucks 1)because my dealer is gay 2)because the brite box is $100.
Someone find a fix
Old May 20, 2009 | 10:35 PM
NoBlinger's Avatar
NoBlinger
You have 2 options brightbox or starscan. Thats it. Unless you drop to your knees for your "gay" dealer.
