5 Gear Transmission
Old May 25, 2009 | 08:12 AM
Gone Fishin's Avatar
Gone Fishin
6 speeds is even better----it does EXACTLY what I want it to do---I just can't shift as fast as an automatic
Old May 25, 2009 | 10:25 AM
05DodgeRamHemi's Avatar
05DodgeRamHemi
I appreciate all of the clarification.
Now, if these trucks have two overdrives, then it wouldn't really seem to me that these trucks have a true tow/haul mode right? When I was towing the trailer through the back roads at about 50mph, whenever I'd get stuck behind somebody, I could just feel the dead spot in the transmission...you know, that terrible feeling like it isn't moving and your just better off cutting your losses on keeping momentum and letting off the pedal to let it downshift into third gear. As some of you have already mentioned, I've found it very useful to hit it a little harder to get it up to speed before I let it shift into 4th and 5th gear. I don't oppose the five gears, but I am used to taking it out of overdrive, and it actually feeling like I have a ton of power right there.
Old May 25, 2009 | 11:09 AM
Sock Puppet's Avatar
Sock Puppet
I have 5 gears and absolutely love it! Of course, I have to shift mine manually. I had to look long and hard to find a used 1/2 ton long bed 4X4 with a 5-speed manual. Maybe I'm dating myself, but I remember when the majority of trucks were standards, now it seems like everyone wants an automatic.
Obviously a tranny choice depends a great deal on what your intended use is. If I lived in an urban area with a lot of stop-and-go traffic I might prefer an auto.
Old May 25, 2009 | 11:28 AM
Markmm0000's Avatar
Markmm0000
Doesnt one of the tuners take care of the crappy downshifting?
Old May 25, 2009 | 12:14 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Does your tow/haul also do o/d off? I'm thinking it's only the 06+'s that have it...anyway it would solve your problem completely by only allowing the firs 3 gears.
Yea the predator does...some years have both partial throttle up and down shift like 05 and some years like mine only have upshift right now. But you know they blow trannies after one trip around the block right?
Old May 25, 2009 | 02:20 PM
jnellydodge's Avatar
jnellydodge
05DodgeRamHemi-I came from a 5.9 98' to an 04' hemi so i'll share my .02 I pull a 30' boat to our lake cabin once a year, its the heaviest load i pull. My 98' would lock out o/d and be screaming down the highway at 3k @ 65. I have to go up a fairly steep grade on the way, and i would loose speed even when floored. This weekend was the first time my 04 pulled the boat. With my hemi (tow/haul only i dont have an o/d off) the computer kept my RPM's at about 2,300 @ 60ish when i had a 10-15mph headwind and on a flat road with little headwind upshifted so i was well below 2k. My fathers silverado does the same thing when he tows. I know what you mean about how it feels different than your 2nd gen, but these newer trucks are set up to be economical (and annoying). The computer thinks it doesnt need the power so it upshifts as it would without a load behind it. Put a good load on your truck and it will behave similiar to your 98'. And as for that grade, i actually gained speed when the truck downshifted, and best of all, a new Ford pulling a slightly smaller boat behind me got to watch my rig fade into the distance as he struggled up the hill. Gotta love these trucks!
Old May 25, 2009 | 04:04 PM
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by 06 Ram5.7
I know that, but my problem with o/d gears, at least with an automatic, is that if you’re in o/d, and you want to pass someone, speed up, etc., you have to floor it for it to downshift. Although, it’s not as bad with 4.56 gears, I actually speed up a little bit when I hit the gas, and I don’t have to floor it to downshift anymore.
Not an issue with a Diablosport Predator. It downshifts out of 5th quite fast with the latest update. No more lag like stock and with a SC tuner.
Old May 25, 2009 | 05:07 PM
06 Ram5.7's Avatar
06 Ram5.7
While I do like some of the features that the Diablosport has that the SC doesn’t, like I said before, with the gears, it’s not really a problem anymore. And I don’t really feel like paying $400 for another tuner, when the SC is fine for me at the moment. Plus, I have a list of things I want to do to my truck, and I can use the $400 for them. But maybe, later on, depending on whether or not SC actually adds any of the options they’ve been talking about, I may end up buying a DS or SCT tuner.
Old Jun 5, 2009 | 03:53 PM
hometheaterman's Avatar
hometheaterman
You mentioned in other posts you didn't like manual transmissions or see what they were good for. This is precisely one of the things that they are good for as a manual transmission would not be doing this. You could make it shift or be in whatever gear you wanted whenever you wanted it to and it would stay there.
Old Jun 5, 2009 | 07:56 PM
05DodgeRamHemi
To me, I would much rather experience the annoying lulls of an automatic transmission, than to have the full time job of shifting my vehicle. Yes, those times your stuck behind somebody causing you to upshift and downshift is annoying, but most of the time an automatic is extremely relaxing and enjoyable.
