Gas Smell in Cab
Old May 27, 2009 | 01:43 PM
daddykirbs's Avatar
daddykirbs
Default Gas Smell in Cab
Hey guys... got a 2003 Ram QC 4x4 with the smell of gas in the cab. The truck also stalls sometimes when I slow to a stop. There is some inconsistent idle when cold as well.
I did the search here and came up with the following.
  • Clean Throttle body
  • Replace EGR valve
  • check evap system for leaks
  • check for bad throttle sensor
  • fuel module? (not sure about this... but it was in the search)
  • check throttle position sensor
Am I missing anything?
I know this has been answered a few times, but not all in one place. I just wanna make sure I didn't miss something important.
Old May 28, 2009 | 12:26 AM
Cheeech's Avatar
Cheeech
Clean or replace the IAT valve. Mounted to the T/B
Also, plugs are due every 30kmi. bad plugs will give gas smell and erratic idle.
Old May 28, 2009 | 08:53 AM
daddykirbs's Avatar
daddykirbs
Thanks, I'll check it out.
Old May 28, 2009 | 08:59 AM
daddykirbs's Avatar
daddykirbs
It's unclear to me what the IAT valve is... is there a different name? Does someone have a link to a diagram?
Old May 28, 2009 | 09:00 AM
Cheeech's Avatar
Cheeech
IAC sorry. Idle Air Control not the intake air temp sensor..lol
Old May 29, 2009 | 10:57 PM
daddykirbs's Avatar
daddykirbs
Haven't checked the IAC yet, but I did change the plugs and clean the throttle body. The truck hasn't had the erratic idle yet but the smell in cab is worse... and now I have a check engine light. I'll get the codes tomorrow hopefully and have a better clue.
Old Jun 3, 2009 | 12:48 PM
daddykirbs's Avatar
daddykirbs
Replaced the hoses on the evap canister and it seems like the gas smell is going away. I still have the check engine light on.... does that go off on it's own?
Old Aug 17, 2009 | 11:58 AM
daddykirbs's Avatar
daddykirbs
UPDATE: The gas smell did go away but within a week or so of doing that work the erratic idle returned. I researched and hesitated for a good long time because I didn't want to just start replacing things because it "might be the problem". I recently read a thread on here where someone said it was the TPS and it fixed his problem. I took a gamble on that one because it was easy and cheap. Well, it worked! My truck is running smoothly once again. Thanks!
