Old Aug 5, 2015, 09:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Weird Air Conditioning Problem
Old May 29, 2009 | 12:57 PM
truckin151's Avatar
truckin151
Not a problem... Hope you are able to track down the problem and get it fixed.
Old May 29, 2009 | 02:06 PM
cmherrmann's Avatar
cmherrmann
Double check to make sure you have enough freon in it. You could have a slow leak and have lost some of the freon. Low on freon will cause the compressor to kick off just like you are describing. Rams are infamous for leaking at the condenser under the dash and it is a pain in the butt to change out.
Old May 29, 2009 | 04:16 PM
cpukramer's Avatar
cpukramer
Thanks ... I just double checked again and the refrigerant pressure is perfect ... so I know the refrigeration system is good ... I must have a problem with the electrical or mechanical ... I am guessing mechanical.
