C Code?
Old May 28, 2009 | 01:28 PM
1LowRam's Avatar
1LowRam
Default C Code?
I got this message earlier when doing the gauge sweep. Then it showed two sets of double zeros. Does this mean anything bad? I did do a search on here for it, but nothing came up.
Old May 28, 2009 | 02:08 PM
BEAR's Avatar
BEAR
If I'm not mistaken I think that is standard. I would have to go out and do mine but I think everything is ok. Your not having guage problems are you?
Old May 28, 2009 | 02:12 PM
1LowRam's Avatar
1LowRam
Nope. Just heard how to check it, and wanted to test it.
Old May 28, 2009 | 03:08 PM
truckin151's Avatar
truckin151
After turning the key on-off-on-off-on does it flash "done" followed by "----" then back to your OD reading? If so then its fine.
Old May 28, 2009 | 03:58 PM
1LowRam's Avatar
1LowRam
Will try that out.
Old May 28, 2009 | 07:06 PM
1LowRam's Avatar
1LowRam
Couldnt get it to do anything. Maybe cause mines a manual and you gotta push the button?
Old May 29, 2009 | 12:41 AM
truckin151's Avatar
truckin151
This is how I have checked mine for codes....
http://s185.photobucket.com/albums/x...28-09_2135.flv
Old May 29, 2009 | 12:58 AM
BEAR's Avatar
BEAR
I think he is doing a guage test where you have the switch off and then press and hold the reset button and turn the ignition switch to on.
Old May 29, 2009 | 09:42 AM
truckin151's Avatar
truckin151
Oh okay my bad, I thought he was doing the other one.
