what is wrong
Old May 29, 2009 | 11:39 AM
timmac's Avatar
timmac
Default what is wrong
for about the last 5 months when i start my 05 dodge ram 1500 4.7 and put it in drive or reverse, it does not want to go. i push on the gas and it revs up and then finally starts to move real slow. what could be the problem?
Old May 29, 2009 | 11:41 AM
Markmm0000's Avatar
Markmm0000
I had the same problem for about 2 seconds after starting my truck the other day. Thought I shifted into neutral and looked down and I was in drive :X Although it went away in about 3 seconds.
Old May 29, 2009 | 11:42 AM
BEAR's Avatar
BEAR
Fluid low? Tranny going out? Not really sure, could be a few things.
Old May 29, 2009 | 11:46 AM
Cheeech's Avatar
Cheeech
I would say it's a delayed response from a sensor. A sensor is what determines where to put line pressure. i would check the connections or maybe even replace it. I don't believe any codes will appear unless the ecu gets no feedback from the sensor, so it's a guessing game until then.
Old May 29, 2009 | 12:06 PM
Riccs22's Avatar
Riccs22
i had the same prob and so did alot of other guys on the forum and the answer is it is simply the trans. the trans fluid doesnt get pumped quick enough on start up wait about thirty seconds before puttin it in gear and your prob should be solved the dealership wont do abything about it either except change filters if it is under waranty
Old May 29, 2009 | 02:14 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
there was something i read about taking out a little plastic valve in one of the lines. it's the stupid little plastic valve that gums up or something. drainback valve maybe?
Old May 29, 2009 | 02:48 PM
daragez's Avatar
daragez
check on your battery too.
Old May 29, 2009 | 03:18 PM
BEAR's Avatar
BEAR
I would like to know more about that feejay if you have anymore info.
=daragez;1683722]check on your battery too.
your battery? Hows that man?
Old May 29, 2009 | 04:27 PM
MikeHTally's Avatar
MikeHTally
I'd say low fluid. And, no, it isn't the battery.
Old May 29, 2009 | 04:30 PM
big guy's Avatar
big guy
The drain back valve is loacted in the trans cooler spin on filter. I had the same problem on my 03. The answer is to drop your trans pan and replace the spin on filter. At the same time should change the flat pan filter as well.
Here is a link to the 06 recall.
http://www.wkjeeps.com/recalls/csn_e1605.pdf
