QUICK HELP NEEDED - 0456 code
Old May 30, 2009 | 10:07 PM
LBs Laramie's Avatar
LBs Laramie
Default QUICK HELP NEEDED - 0456 code
so i did a search and see that this is an emissions leak - checked gas cap - its fine. my question is, i'm driving 10 hours tomorrow am - is this safe? should i stay an extra few days to get fixed before the trip?
thanks!
neil O.
Old May 30, 2009 | 10:19 PM
MontanaRAM's Avatar
MontanaRAM
mine's been throwing the 0456 code for over a month, it hasn't affected my rig at all. i also have no plans on fixing it anytime soon. go ahead and drive.
Old May 31, 2009 | 09:07 AM
jk360's Avatar
jk360
check the hoses on the under carraige where the evap charcoal canister is on the driver side.. might have a few small cracks. happened to mine and just fixed it last week.. simple fix
Old May 31, 2009 | 10:18 AM
pdavis53's Avatar
pdavis53
This is what I did for the Second time yesterday and I finally found a hose on the top that was cracked. I had to remove each hose before I found it but I finally found it. I reset the computer and towed my boat all day yesterday and so far no engine light. Hopefully I fixed it, I guess we will see. Good luck.
Old May 31, 2009 | 11:48 AM
BEAR's Avatar
BEAR
+1 ^^^^
Old May 31, 2009 | 12:24 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
thanks!
neil O.
How did you check the cap...just glancing at it doesn't count. Replace it
