remove radio 2006 automatic
take a small plastic screwdriver (or something that isn't going to scratch bad) and stick it in the gap between bezel/dash in upper left hand corner (by gauges)push in and pull towards you, it will come out and work your way around! Easy
There are 2 screws underneath that need to be removed, then the bezel just pops off. It takes a little force, but it will come off. If you have a center console, you will have to remove that first to get at the 2 screws. they are at the bottom facing upwards. Circled in red in the attachment.
