3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
off and on in the past 2 years when i put the truck in reverse and backing up VERY slowly the truck would bog down and sometimes die. it doesnt happen often just random times. i talked to the shop and they said they would charge me if they could not duplacate it just to check it out, but it doesnt happen often enough for me to do that. does anyone have an input on this?
Only way to properly tell plugs comubustion temp is to run WOT on highway for a brief period and then shut the truck off and roll to a stop.
And then what? The temp a plug runs at is determined by the depth of the well around the center electrode. Shallow= cold running plug, deep= hot running plug. You can tell alot by pulling the plugs and reading them.
