Lift Question?
Old Jun 14, 2009 | 04:23 PM
dazed01's Avatar
dazed01
+1 on the alignment too. It messes the toe up.
Old Jun 14, 2009 | 04:35 PM
AirBorneRAM's Avatar
AirBorneRAM
is there any rubbing at all cause thats one thing i want to avoid , i do plan on going off roading and as for turning radius , do you have any rubbing on the fender walls or anything
Old Jun 14, 2009 | 04:51 PM
HammerZ71's Avatar
HammerZ71
If you do the crank to level and then add a 3" body lift you would have enough room in the tire wells for decent articulation.
As far as scrubbing, if you use an aftermarket wheel with around 4.5" of backspacing and stay at or under a 12.5" wide tire, you'll be fine...
Old Jun 14, 2009 | 04:57 PM
dazed01's Avatar
dazed01
I have no rubbing going offroad with 4.5" backspacing and 35x12.5 tires.
