Please help me
Old Jun 13, 2009 | 09:13 PM
badfish88's Avatar
badfish88
Default Please help me
04 DODGE ram hemi, i pluged my boat in this mornin and the tail running lights did not work, but the brake and blinkers work. i unpluged the boat, and now the trucks tail running lights and front side lamps dont work now, but blinkers flashers and brakes work. i dont have the lamp out signal, and checked all fuses on the diagram in the service manual, all good and checked the relay switch with one out of a good truck, same model and still did not work. so all fuses and the relay is good, and i have no tail running lights, or front side lamps when the lights are on, just high and low beams. im dumb founded......i cant figure it out. i googled it and all i found was that the guy replaced the entire fuse box cause the dealer said there was a bad wire and it had to be replaced. please help
Old Jun 14, 2009 | 04:55 PM
John  M's Avatar
John M
If the 2004 wiring is the same as 03, it looks like you need to check Fuse 15 and the parking lamp relay. They're immediately upstream from the truck and the trailer tail circuits.
This also assumes the stock tow package and not an add-on.
Old Jun 14, 2009 | 05:12 PM
badfish88's Avatar
badfish88
the relay is fine, i checked it with a working one, i also checked all fuses and all of them have current flow. thats why im so confused
