Clearance question
Old Jun 14, 2009 | 11:48 AM
MeAndMyHemi's Avatar
MeAndMyHemi
Default Clearance question
Here's the deal. I ordered a set of 305/ 50 - 20 sneakers for the buggy.
Here's the question: With factory 20's will I have any issues with clearance in the front? If so, will the coil spacers clear it up?
I already have a set of drop shackles for the back (Not installed yet) to level it out but will change gears and use coils in front if necessary.
Then I will be selling the drop shackles...
Old Jun 14, 2009 | 12:11 PM
dirtydog's Avatar
dirtydog
Moderate User
305/50/20 is actually one size smaller than stock 33" in height. No problems at all. a 275/60/20 is a taller tire than the 305/50. Even if your lowered you shouldn't have any issues. a 305/50 is 1" wider and 1" shorter than stock.
Old Jun 14, 2009 | 01:57 PM
MeAndMyHemi
Thanks. Here's a stupid question: How did you put your truck pic in your signature block?
Old Jun 14, 2009 | 02:05 PM
dirtydog's Avatar
dirtydog
Moderate User
For the sig, I shrunk the original down to 20% in Paint program under "Image" and scroll down to resize/skew. Both 20%. Then go under User CP and download.
For ALL other pics that you would insert into any post, I use Photobucket and the [img]url using the Earth link button at the top of this message box. Then you can load as many pics in a thread as you want.
p.s. not a stupid ?
Old Jun 14, 2009 | 02:48 PM
nim81's Avatar
nim81
another great free program for resizing pictures is irfan view. super easy to resize and you can save a picture to what ever format you wish.
Old Jun 14, 2009 | 06:29 PM
HemiLonestar's Avatar
HemiLonestar
They work just fine on a 2wd 2003 Lonestar.
