torsion bar crank mod
Old Jun 15, 2009 | 02:11 AM
98cherryram's Avatar
98cherryram
Default torsion bar crank mod
This is a question for the guys who have done it without the key, when you lifted it, how much does the bolt have to move to gain successful lift in reality, say if my bolt only looks like it can only go up an inch, will that give the suspension just an inch of lift, or will it give it like 2 inches because of angles and such? Im about to do this tomorrow on my 02 ram sport that I just got on saturday. thanks for the help.
Old Jun 15, 2009 | 03:07 AM
BEAR's Avatar
BEAR
Its hard to say how much a inch of bolt would lift the front end. What you do is on a level ground, measure the distance you have now from the top of the tire to the fender well, raise the front tires off the ground to take the load off, put the truck on jack stands and crawl under there and crank a few turns. Set the truck down and measure to see what you have gained and to make sure both sides are the same. Repeat until you are out of adjustment or you reach the lift you want. Then go get an alignment done.
Old Jun 15, 2009 | 03:25 AM
98cherryram
Alright, I was just curious to see if anyone else felt that same way when they went to do theirs, almost like, wow, is that enough to even make a difference, I really feel like my front end sits pretty low also... so maybe its not for every inch of the bolt you gain an inch of lift, maybe its like per inch of bolt 2 inches or something. I sure hope so!!! Ill post pictures of my new pickup tomorrow, before and after I torque it!!
Old Jun 15, 2009 | 05:29 AM
Martin460's Avatar
Martin460
For an inch of lift i turn the bolt 5mm.(1/5 inch)
Old Jun 15, 2009 | 07:31 AM
abarmby's Avatar
abarmby
Be careful as to how much lift you attain.
On a 4x4, the CV axles will and do, get damaged by too acute an angle on them.
You can get everything from torn CV boots, to an actual prematurely worn CV joint from cranking too much.
More experienced guys on here will chime in about what is considered the max lift using this technique.
Measure as previously stated on a flat road, with a tape running through the center cap to the bottom lip of the wheel arch.
I believe from memory, a measurement of 41.5 - 42"'s with 20" wheels and the standard 175x60xR20 tyres, is maxed out???
Hope this helps?
Al.
Old Jun 15, 2009 | 08:22 AM
HammerZ71's Avatar
HammerZ71
and don't over do it. Al's correct about keeping an eye on the CV angles. 2.25" is what's needed for perfectly level. 2" would be about the max I'd go, after that, you also start to put a lot of torque on those torsion bars. I've never seen one fail, but it does make for a real stiff front end if you go too far...
Old Jun 15, 2009 | 08:51 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
yea, inch of bolt is plenty. happy cranking!
Old Jun 15, 2009 | 09:01 AM
nim81's Avatar
nim81
8 full turns on each of of my bolts gave me 3"
Old Jun 15, 2009 | 09:33 AM
jonnymagnum's Avatar
jonnymagnum
I turned my bolts 5 turns and got 2" just make sure you measure both sides before and after so you know if its level.
Old Jun 15, 2009 | 11:16 AM
98cherryram
Thanks guys!! great advice, Im real excited to get this done! At first I was really sad to leave the straight axel setup thinking I would have a hard time getting it leveled, now Im really happy, it seems like this is a great solution to that. I will measure it, I only want to go about an inch and a half, my truck has that front end look that still looks good if it at least stays a little lower than some trucks, and for me to say that is saying a lot, because lifted trucks are my deal... but I like the class in this one. Again, thanks to everyone for the help!!!
