RPM Surging
Old Jun 16, 2009 | 03:33 PM
  #21
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by Pyro
Well, well, well, the Cow Chick got it right. Just for the record, I knew the solution before posting the problem, it took Hammer all of 4 seconds to figure it out. The problem hadn't occurred around town because I haven't done much in town driving, mostly highway. It's a bad wire, running to the #5 cylinder plug.
Damn, I suck. I would have bet on TC lockup problems from the way you described the surging on the highway. Now I am going to go away my sorrow from being dumb .
Old Jun 16, 2009 | 03:54 PM
  #22
Pyro's Avatar
Pyro
I Beat Tetris
Originally Posted by Off_Road_Teacher
I would have bet on TC lockup problems from the way you described the surging on the highway..
If it makes you feel better, that's what I thought too at first.
Old Jun 16, 2009 | 05:51 PM
  #23
ramhunter9's Avatar
ramhunter9
Damn, Now I am going to go away my sorrow from being dumb .
pull up a seat bud welcome to my world
Old Jun 16, 2009 | 05:59 PM
  #24
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
well you should have stated that in the problem shouldn't you have?
mann, i quit drinkin, i feel like such an *******
Old Jun 16, 2009 | 06:06 PM
  #25
abarmby's Avatar
abarmby
Wink
Me too.
From the description, I thought it must be the TC.
But......Pyro didn't give us all the info ...........
Anyway, that's what I'm sticking with lol.
Old Jun 16, 2009 | 06:12 PM
  #26
Pyro's Avatar
Pyro
I Beat Tetris
I gave y'all the same info I gave Hammer
Old Jun 16, 2009 | 06:15 PM
  #27
HammerZ71's Avatar
HammerZ71
Not to toot my own horn, cause even a blind dog has a rabbit run right under his nose once in a while, but I had the same story last night on AIM, that y'all got.
Pyro stated that he thought his TC was going and I asked him the symptoms, then asked him if the tranny was slipping during the surges, because that's what happens when the TC "slips".
I knew at that point that a cylinder was not firing off intermittently (and you won't get a CEL if the cylinder fires off the next time). The truck had to rev higher to maintain speed with seven working cylinders. So a problem within the cylinder (piston, lifter, etc.) was possible, but usually not the case with an intermittent problem. Broke parts as a rule, do not fail, work, fail. Only things do that are damn electical problems. So I told him to get his a$$ outside and check his plugs and wires, figured it was a severely cracked boot...
BTW Pyro, get you a new wire set yet?
Old Jun 16, 2009 | 07:48 PM
  #28
gmb4fords's Avatar
gmb4fords
my truck surges sometimes at idle but not when driving, that i can notice. thought it was a dodge thing... should i check my wires too or does hammer know of another problemi should check out?
