How do you Do your own tranny flush?
I have searched but can't find a good explaination.....couple of questions:
1. what is the order of flow? I know the fluid gets pumped from the pan out, but does it go through the torque converter then through the cooler back to the pan or other way around?
2. Which line coming off the cooler do you disconnect when doing the flush? Upper or lower when standing in front of truck?
This is how I figured how to do it:
1. Drop tranny pan and change filters and clean pan
2. Re-install pan with new gasket/rtv
3. Fill pan back up with new fluid to proper level
4. Disconnet the line from the cooler that returns back to the tranny and dirrect into a drain pan
4. Start Vehicle
5. Add 1 quart to pan as its running/draining
5. Stop truck when the return line stops draining
6. Reconnect return line
7. Add fluid to proper level
8 Start truck/add fluid til proper level is reached
Would this process work? In theory when you drop pan all the fluid is changed in there, then when you start it up it should use that new fluid to push out all the old through the torque converter and cooler right? Input would be great!
4. Start Vehicle
HOLY CRAP
After a bunch of searching I found this.......
http://www.60ateight.com/DodgeRam/Ra...uid_change.pdf
All questoins answered. This should be posted in the FAQ DIY section for sure!
1-4 is correct, but I would overfill by an additional 2 qts.
Start the truck and wait for the fluid to sputter and spit. Shut truck off. Pour 5qts in start your truck. No need to hook the return line up for the re-fill, leave it off the entire time. Wait for sputter and repeat 1 more time. Then add 4qts and get the truck up to operating temp and fill to desired level. That's it. I'd pick up 2 cases and bring back what you don't use. Your gonna use 17/18qts.
boy 17-18 quarts at $6 a quart.....I might look into having a shop flush it for me. I am pretty sure I should be able to get it flushed for around $100 or so. Its going to cost me $108 in just fluid!
http://www.autozone.com/autozone/cat...smission+Fluid
I called all around and Autozone was the cheapest
Durablend is not on the list and if its a blend that means its mixed with non-synthetic fluid as well........no thanks
Trending Topics
I guess this is the complete list:
Advance Auto Parts ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Conklin ATF-Xtra Plus ATF+4®
Formula Shell ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
MotoMaster ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Quaker State ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Texamatic DC ATF+4®
Ultramax ATF+4®
Valvoline ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Chevron ATF+4®
Coastal ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
MotoMaster ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Quaker State ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Texamatic DC ATF+4®
Ultramax ATF+4®
Valvoline ATF+4®
