Hella 500 wiring (dont kill me)
Old Jun 16, 2009 | 06:36 PM
DeaDinside's Avatar
DeaDinside
Default Hella 500 wiring (dont kill me)
Hey,
Can someone send me the link to wire the hella 500 lights up, without wiring them to the highbeams...i cant seem to find the right link on here...THANKS
Old Jun 16, 2009 | 06:58 PM
cluffdaddy's Avatar
cluffdaddy
i just wired mine up last night. all you have to do is connect the wire (mine was green) that is supposed to tap into the highs and run it to the battery... just make sure you dont cut out the in-line fuse. then you will be able to turn the hella's on at will.
Old Jun 16, 2009 | 07:04 PM
dirtydog's Avatar
dirtydog
Moderate User
Bad idea. That means your running 16amps through the 10amp rocker switch that comes with the kit. You must upgrade at least the rocker switch to do that.
here's the link scroll to post #18 https://dodgeforum.com/forum/off-roa...oad-guide.html
Old Jun 16, 2009 | 07:42 PM
DeaDinside's Avatar
DeaDinside
Thanks...
