Custom Stereo Build
Oh and to answer the other part of your question Twink, it is a ported box. Demensions are as follows:
Common chambered (Subs share air space) 6 cubic ft.
Port: 4x10 by 9.25" deep, tuned at 35 hz
Subs are dual 4 ohm coils wired to 1.3 ohms at the amp pushing about 1300rms 2600 peak wattage. Main Power cable will be a 2/0 run, with 150 amp main fuse, and distribution fuse block with a 100 amp for the sub amp and a 40amp for the high's amp.
Well I accomplished quite a bit more tonight. But I only have a couple of photos.....Will take more tomorrow before I continue on....I removed the center seat, the rear storage bin, and center seatbelt system. I test fitted the box, and built my center console. Tomorrow on the agenda I plan on finishing the vinyl on the box and mounting it behind the seat. Then I plan on running my main wiring and covering the center console. Well here are the Pics....
I know I have to make some trim plates as well for the EQ's and the subs are in and wired as well. I also ran the main power wire, all the RCA's. The box with the fans is the new center console/amp rack. There is a slot in the bottom front and the fans will pull the heat out....Keep the comments coming.....
