Window Lockout button
I just bought an '04 Dodge Ram Hemi 4 door. All the windows work but only from the driver's controls. The window switches on all the other doors don't work. It does this with window lockout button up and down (doesn't matter). Has the window lockout button gone out? Is it hard to change?
Thanks!
Brock
Thanks!
Brock
check www.rockauto.com
you might have to replace the whole control panel if the lock button is bad.
try bypassing the switch to see if the other windows work.
maybe check the fuses
I have the same problem with my 2004 2500 Quad Cab. I recently bought the drivers side control module and this did not solve the problem. It seems that the lockout control is the cause. I have checked all fuses and they are fine. I check the passenger door with a test meter and there is not any elctrical current or power till I use the main drivers side button. I am going to try to find out how to bypass the lockout control. The lockout color code is the orange and light blue wire.
Won't be the fuses. Common problem, though. I have to take my driver's side panel out every so often, unplug/replug -- all good ('til next time). Annoying, but I've not spent the money or taken the time to dig deeper.
