02 sensor, help
Old Jun 23, 2009 | 01:56 PM
mcgoo89's Avatar
mcgoo89
Default 02 sensor, help
i have on 02 4.7 engine 1500. i had a check engine light on, so i went to auto zone and it cme up bank 1 sensor 2, driver side back sensor, right? well i crawl under the truck and all i can find are 2 sensors which are on the exhaust pipe. neither of them are the one i want, right? can anyone tell me where the one i want is?
Old Jun 23, 2009 | 02:15 PM
HammerZ71's Avatar
HammerZ71
I am almost certain you only have one cat, therefore you should only have 2 O2 sensors, one before and one after. Sensor 2 will be the rearmost one, the one after the cat...
Old Jun 23, 2009 | 04:24 PM
mcgoo89's Avatar
mcgoo89
are you guys sure about that? the idiot at autozone told me i have 4
Old Jun 23, 2009 | 05:52 PM
HammerZ71's Avatar
HammerZ71
I know for a fact that the '03 Hemi's have only one cat, they went to 2 cats in '04. So I really can't see your '02 4.7 having 2 cats. But hell, if you crawl under you can't help but see a catalytic converter.
Old Jun 23, 2009 | 06:28 PM
lxman1's Avatar
lxman1
Site Moderator
Same as the 96 Indy pace truck 5.9L that I worked on this weekend had the same code but for sensor 1 (before the converter). It only has one of each as well.
Your Y-pipe should come down from the manifolds and go into one converter, There is a sensor on the engine side of the converter and one on rear side. The rear side is the code that you are getting.
