Freeze plug/core plugs
Old Jun 30, 2009 | 11:37 PM
myram's Avatar
myram
Default Freeze plug/core plugs
Ok so today i finally got fed up with putting fluid in my housing like every 3-4 weeks i knew i had a leak but i had no days off to look for it.... Well i finally got a day off... i took it to school and put it on a lift....i noticed this line of Rot/corrosion.... oh boy right... followed it to a freeze plug/core plug what ever you wanna call it.... well its right next to the engine mount... was wanting to know what would be the best way to go about replace that freeze plug with out doing harm to my engine... or if there was a how to.... and correct me if im wrong but isn't there like a seal on it... not like rubber or anything but like glue or something? i heard about just taking a screw stick and hammering one side till it flips then grabbing it and then hammering it with a socket on it... but can it really be that easy?
Old Jun 30, 2009 | 11:54 PM
dirtydog's Avatar
dirtydog
Moderate User
Drain the coolant and punch a hole in the plug so you can pry it out. The problem is getting the new one on!!!!!!!!!
Old Jul 1, 2009 | 12:00 AM
myram's Avatar
myram
Yea i just didn't know if i should put it on the lift.... and take it out or try and do it in my drive way....
Old Jul 1, 2009 | 07:18 AM
RubberFrog's Avatar
RubberFrog
Everything is easier on a lift! I like to hammer them back in using the biggest socket that will fit in the plug, they have to go in straight. Can you get a square blow to it with the engine mount there
Old Jul 1, 2009 | 02:00 PM
myram's Avatar
myram
that idk i have to get back under my truck....
