Torsion bar question
Old Jul 1, 2009 | 06:27 PM
Muppet's Avatar
Muppet
Default Torsion bar question
cranked the bolts down on the bars, but the driver side seems to sit lower than the pass side, no matter how much more I crank the bolt on the driver side the pass side still stays about 1/2" higher. Also do you guys normaly just crank them untill they hit the little lock in there?
I have a apt to get the alignment on Monday, and i will be looking for longer shocks also.
Old Jul 1, 2009 | 06:40 PM
ramhunter9's Avatar
ramhunter9
you need to back them out with the tires up in the air to realive preassure.. then make equal turns on the bolts
if that dont work you have a full gas tank
Old Jul 1, 2009 | 09:16 PM
jonnymagnum's Avatar
jonnymagnum
ya I only had to crank mine 5 turns to get 2" outta them. you definatly dont wanna be cranking them too much and put too much stress on it. make sure you jack the tires off the ground. and take it for a drive after so everything will settle back down. then do your final measure.
I just did my 2" drop shackles and it took a good 2 days of driving for them to settle down.
