is it normal for temp to rise after turning off truck?
Subscribe
Jul 5, 2009 | 09:01 AM
Without the motor running turning the fan/water pump the temps will always rise a bit. I don't have my e-fan run after shut-down, since nothing would be cooled except the coolant in the radiator.
Reply 0
Jul 5, 2009 | 11:07 AM
ya these are some good tips especially in this hot july weather. So people with electric fans do you guys still have your clutch fan?
Reply 0
Jul 5, 2009 | 03:19 PM
The only reason I would go to an electric fan for main cooling is when I switch engines (eventually, hopefully) and I need that 6.1 intake which you absolutely have to get rid of the clutch fan.
Reply 0
Jul 5, 2009 | 04:31 PM
Quote: Some people will wire in an electric water pump to go with the e-fans so the coolant circulates.
I like that idea. toss the clutch fan and mehanical water pump at same time.
Wonder if you could so same with an electric oil pump and an oil cooler?
Reply 0
Jul 5, 2009 | 05:52 PM
Quote: I like that idea. toss the clutch fan and mehanical water pump at same time.
Race cars do the electric water pump thing all the time, less drag = more hp = better ET's. I don't know if you could REPLACE the factory oil pump, but there are prelube systems that get the oil pressure up some before startup, mostly for diesels.
Reply 0
Subscribe
