How to paint a sub box??
Old Jul 6, 2009 | 12:44 PM
Markmm0000's Avatar
Markmm0000
Ive painted sub boxes before and it always always always comes out with pin size holes all over it no matter what kind of thick primer i use. I suggest using puddy on most of the pours then priming the crap out of it with the thickest junk you can find. If you have access to some decent paint supplys then i suggest clearing it and waiting overnight sanding it and clearing it again then use a low grit paper and buffing it if you know what im talking about :X
Old Jul 6, 2009 | 01:38 PM
magnethead's Avatar
magnethead
yea, painting and MDF do NOT belong in the same paragraph.
Old Jul 6, 2009 | 01:48 PM
tuned93's Avatar
tuned93
i say bondo the seams, primer.. and then walmart sells this "hammered finish" paint in a rattle-can. that should hide the wood surface while giving it a unique look. it comes in a few different colors.
Old Jul 6, 2009 | 02:56 PM
Markmm0000's Avatar
Markmm0000
btw my experience when painting sub boxes are with HVLP spray guns not cans of paint. if u want u can prime it thick as hell with a spray can primer then roll on single stage with a paint roller ( yea like for your walls) you would be surprised how nice it comes out.
Old Jul 6, 2009 | 11:47 PM
Dodgeboy77's Avatar
Dodgeboy77
Any wood covering I was always taught to bondo the seams and prime it many times, then sand it smooth. you might have to do it a couple of times but you always sand it smooth between 4 or 5 coats (that might have been thinner primer)
Old Jul 7, 2009 | 12:27 AM
tuned93's Avatar
tuned93
you can get sandable auto primer, just spray it on thick, after sanding you wont have the wood "swirls". thats in addition to the bondo-ing of the seams. but for all intensive purposes, you would be better off just getting some material i.e. (p)leather, carpet, etc. and just covering it that way...
Old Jul 7, 2009 | 12:40 AM
Bigc9164's Avatar
Bigc9164
ya thats what im gonna do
Old Jul 7, 2009 | 12:43 AM
tuned93's Avatar
tuned93
right on, well post some pics when you get it finished!
Old Jul 7, 2009 | 07:02 PM
soundwavesram's Avatar
soundwavesram
I would suggest going to your local paint suppy store and looking into getting gel coat to paint it with. Gel coat is pretty common when painting interiors to match exteriors.
Old Jul 7, 2009 | 07:31 PM
ramhunter9's Avatar
ramhunter9
your box is not going to fit well because you didnt cut around for the seat belt just my opinion. look in my pics under sub to see a custome job...not sayin yours isint but it wont sit flush to the back cab wall and you wont be able to use your middle flip up center console.
and for the record i pianted mine with rhino linning tuff as nails
