Headlight question
Old Jul 6, 2009 | 11:17 PM
cjs4444's Avatar
cjs4444
Default Headlight question
OK so i have a question about my headlights.....it seems that something is just not right....the light output doesnt seem to be even on both sides.....ie. the out put on the driver side is alot more than the passenger side....also no matter what adjustment i make i cannot make the light pattern on the ground even.....all i see is streaks almost...anyone ever had this problem or have seen this before.....and they are stock headlights.
thanks
Old Jul 6, 2009 | 11:32 PM
AF_HEMI's Avatar
AF_HEMI
headlights dim as they get older. try replacing the bulbs with the silverstars or something brighter if you dont wanna take the HID plunge.
if your lenses arent crystal clear, you may wanna pick up a headlight defogger/cleaner from anywhere like walmart. it gets rid of the fading and such from the sun.
Old Jul 7, 2009 | 12:03 AM
cjs4444's Avatar
cjs4444
well it was bothering me because i just put HID's in....so i went and pulled the drivers side out...which is the one that seems brighter...and sure enough the horizontal adjustment was broken....the screw was in two....so i imagine that was causing it not to be able to be adjusted and so therefore could only go up and down....does anyone know if you can buy just that adjustment piece or do i need to get new headlights all together.
