Dead power door lock and power window
Old Jul 7, 2009 | 01:42 AM
romangiberson's Avatar
romangiberson
Default Dead power door lock and power window
My rear driver side door power window and lock went out at the same time. Neither can be operated from the master switches or the passenger door itself.
Any ideas?
Old Jul 7, 2009 | 07:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Have you traced and checked your wiring to that door? If everything else works fine and the power for the windows goes through the window lockout switch on the drivers door then I would think it is something in the door. A lot of people see to have issues in the wiring in the rubber boots on the doors where the wire gets pinched and broken over time. You may want to check that.
Old Jul 7, 2009 | 09:44 PM
eaglestorm's Avatar
eaglestorm
WEEDAHOE is right ck the harness in the rubber boot for the rear door wires break all the time
Old Jul 7, 2009 | 10:52 PM
gmb4fords's Avatar
gmb4fords
i am havibng the exact same problem im going to check it out tomorrow
Old Jul 8, 2009 | 12:32 AM
Martin460's Avatar
Martin460
Some months ago my left rear door power lock went out. Wire was broken inside the rubber boot.
Old Jul 8, 2009 | 05:57 PM
takin's Avatar
takin
I just worked on this problem a couple of weeks ago. At first it was my speaker crackling then my door lock was intermitten. So, finally I broke down and started investagating the problem. I pulled the door panel off, removed the speaker, removed the interior panel (behind the drivers seat), pulled the rubber boot off (you have to pull it back thru the door to be able to have enough slack in the wires) and found 4 or 5 wires completely broken. Re-soldered them back together and problem resolved. Oh yeah, the door panel comes off sliding it upward do not pull it out or the little plastic brackets break and then you have another problem. So I hear Hope this helps.
TA
Old Jul 19, 2009 | 11:37 AM
romangiberson
Thanks everyone, I'll check the door boot first.
