DIY intakes?
Old Jul 9, 2009 | 03:27 PM
regert's Avatar
regert
Originally Posted by butch1581
I used 4" PVC, glued it all together and ruffed it up with some 200grit sandpaper and used the spray paint that is made for plastic. just make sure the plastic is clean. I used rubbing alcohol to clean before and after sanding and it turnned out great! I made a bracket to support.
My opinion on the dual intake is that its useless unless you actualy extend it down on both sides where it sucks cool air. The ones that are really short suck hot air from the bottom side of the hood. I put mine where cold air comes in behind the headlight and made an air deflector to force air in there....
Do you notice a power gain of MPG, and how does it sound?
Old Aug 25, 2009 | 12:44 AM
004x41500's Avatar
004x41500
i know its an old thread, but what are the part numbers for the parts to get the intake to mount to the TB? or what is it that i need to look for?
Old Aug 25, 2009 | 05:43 AM
Tazman40's Avatar
Tazman40
its called a 3X4 Fernico coupler.
Old Aug 25, 2009 | 11:22 AM
Spokane_Dodge's Avatar
Spokane_Dodge
Size is going to vary depending on whether you use 3 or 4inch piping.
Mine was a 3in x 3in Rubber Coupling.
Old Aug 25, 2009 | 05:45 PM
004x41500's Avatar
004x41500
which would be better 3 or 4 inch tubing? i have a 5.2 magnum
Old Aug 25, 2009 | 06:13 PM
Tazman40's Avatar
Tazman40
Ok,let me clarify,butch1581 used a 4X3 fernico.But you could go with a 3X3 coupler if you used a 3 inch sch 40 pvc pipe instead of 4 inch.It looks like he reduced back down to 3 inch so the 4 inch pvc inbetween is kinda not needed.Its what ever one wants to do.
Old Aug 25, 2009 | 08:54 PM
004x41500's Avatar
004x41500
oh, ok. does home depot carry those?
Old Aug 25, 2009 | 09:00 PM
draco8494's Avatar
draco8494
yup sure do^^
Old Aug 25, 2009 | 09:03 PM
davb673's Avatar
davb673
I used 4 inch PVC for a while, and noticed a little hp increase and noise increase. I have since switched to a 3.5 inch steel pipe, and can tell you the steel transmits more noise than the plastic did. Not sure if there is an hp change, but definitely a noise change...
[edit] Butch1581, that looks pretty good...
Old Aug 25, 2009 | 09:06 PM
draco8494's Avatar
draco8494
yeah my aluminum egay intake was ALOT louder than the pvc one i have now
