de-badged, but it left spongy thing and dont come off.
Old Jul 9, 2009 | 04:59 PM
Jarrod904's Avatar
Jarrod904
Originally Posted by truckin151
For which part? Wd-40 removes gunk and grime from paint and it does not hurt it, and the plastic scraper is used to get the corner up so you can peal it off. If you take your time and work it right there is no damage what so ever on the paint. I also used the eraser wheel for a while but that thing got me really nervous when using it because of how hot it got.
i thought you were talking about using the scraper to get the spongy stuff off lol
Old Jul 9, 2009 | 05:04 PM
truckin151's Avatar
truckin151
No I used the scraper for the 3mm tape that was left on the truck, I used the eraser wheel for a while but I didn't like how hot it was getting and not taking anything off (probably a bad wheel) so I pulled up a stool and took my time peeling it off. To get the badges off I had some nylon catfish line that I attached to a short broom handle to save my fingers.
Old Jul 9, 2009 | 05:27 PM
disturbedgator's Avatar
disturbedgator
Originally Posted by Spokane_Dodge
Your finger nail, then an adhesive remover and a peice of cloth. The 3M aerosol can of adhesive remover worked great.
absolutely truf! also make sure to switch fingers alot cause itll give you mad blisters. take your time, dont be like me and have to get a body shop fix my stupid impatience with a razor blade....
Old Jul 9, 2009 | 05:43 PM
Bluesmanjesse's Avatar
Bluesmanjesse
Goo Gone/goof off works great on adhesives,My brother in law always debadges cars at his body shop with a heat gun on a low setting moving back and forth over the badge,you could use a hair dryer I suppose if you don't have a heat gun.
Old Jul 9, 2009 | 06:22 PM
mmstar23's Avatar
mmstar23
Originally Posted by Got_Hemi44
hahah that video was informative and funny as hell at the same time...good work rubber frog!
Old Jul 9, 2009 | 08:35 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I just used a big eraser I got from work. Took it all right off.
Old Jul 9, 2009 | 10:04 PM
jumbonas's Avatar
jumbonas
i think there should be a video of the month. and id nominate that one for july.
Old Jul 9, 2009 | 10:36 PM
tuned93's Avatar
tuned93
i just used goo gone and a towel. just soaking it and rolling the "spongy stuff" in an upward fasion. like half of my fingers had blisters when i was finished, but it was worth it in the end...
Old Jul 9, 2009 | 10:45 PM
BEAR's Avatar
BEAR
The link by Hammer or the video by Rubberfrog is the best IMO I tried all the other ways and finally gave in and bought a eraser wheel and never turned back. As long as you don't run the drill too fast it works great. Slow and easy is the ticket.
Old Jul 9, 2009 | 10:48 PM
sharkhunter10's Avatar
sharkhunter10
1^ i do the same
