View Poll Results: What is your PSI percentage VS. the max cold PSI?
100%
7
38.89%
90%
1
5.56%
80%
7
38.89%
other
3
16.67%
Voters: 18. You may not vote on this poll
What are your Tire Pressures set at?
Old Jul 14, 2009 | 10:48 PM
WeightLifter500's Avatar
WeightLifter500
Default What are your Tire Pressures set at?
I was just doing a thread on tire pressures because they are key to handling, MPG's, and tread wear. That and I didn't see much in the faq's section. State what your tires max cold PSI is and then what you have yours set at.
I have 285x70x17 Khumo AT's. Max cold PSI is 44. I have my front tires set at 38psi and my rears at 36psi. If I load down the bed or am towing the boat I will add pressure to the rears.
Old Jul 14, 2009 | 11:29 PM
dirtydog's Avatar
dirtydog
Moderate User
40lbs all around
Old Jul 15, 2009 | 03:18 AM
abarmby's Avatar
abarmby
Cooper discoverer H/T Plus 265 60 R20 40 lbs all round. With 4 poeple and highway 43lbs all round.
Al.
Old Jul 15, 2009 | 07:04 AM
MikeHTally's Avatar
MikeHTally
Bridgestone Dueler Alenzas, 265-70/17. Max is 44 (I think). I keep 35 all around.
Old Jul 15, 2009 | 08:58 AM
HammerZ71's Avatar
HammerZ71
Max on my FCIIs are 50 lbs, unless going off-road I keep 'em at 40 lbs., so I guess that's right at 80%...
Old Jul 15, 2009 | 11:01 AM
BEAR's Avatar
BEAR
Mickey Thompson ATZ's 305/65/17 max cold pressure is 65, I run around 42 cold.
Old Jul 15, 2009 | 11:10 AM
truckin151's Avatar
truckin151
Yokohama Parada Spec X (275/55/R20) - Max is 50psi and I keep them right at 40psi so 80% for me.
Old Jul 16, 2009 | 12:03 AM
Wanderer's Avatar
Wanderer
Keep 42 front/38 rear, empty, on both my 17s (winter) and 20s (summer). A heavy load brings my rear up to 44.
Old Jul 16, 2009 | 12:10 AM
davb673's Avatar
davb673
Factory 20" Goodyears on my truck still. I had all 4 at 41psi for a while, but it is so bumpy around here I dropped them down to 38. My wife wasn't mad, but I could tell she didn't like all the jostling around.
Old Jul 16, 2009 | 12:13 AM
trinity03's Avatar
trinity03
40 lbs.....
