HID Problems!!!
Old Jul 17, 2009 | 11:47 PM
Twink's Avatar
Twink
Default HID Problems!!!
Its getting dark and im at a friends house.. we wired in my HIDS and when i have the truck off with the lights on the hids kick on and work perfect as well as ejecting the Parking brake without the truck on to trigger the driving lights.
Now when i turn the truck on low beams dont work and then the lights when i turn them on pulse. Ive read up some stuff about resistors and ****.. but right now im split between running a 12v Current to the bulb, to the ballast and then grounding them and using the negative from the oem harness..
Any Quick replies are great
07 Dodge Ram 1500
Old Jul 17, 2009 | 11:57 PM
RaiderJay6's Avatar
RaiderJay6
Sounds like a cheap Ebay kit. Dodge computers are tricky things!
Old Jul 17, 2009 | 11:58 PM
Twink's Avatar
Twink
ya it was fairly cheap.. definitley chinese.. eveyrthing works when the trucks off...
Old Jul 18, 2009 | 12:03 AM
RaiderJay6's Avatar
RaiderJay6
The computer cant see the lights so it will send pulses of power to the lights thats what causes the strobing of the lights.
Old Jul 18, 2009 | 12:05 AM
Twink's Avatar
Twink
but how do i get around that? a resistor?
Old Jul 18, 2009 | 01:00 AM
abarmby's Avatar
abarmby
In a word yes........but I don't have a clue what value.
Your computer needs to see your headlights as a "load". The HID's don't provide this resistive value, like the incandescent bulbs do. Therefore they flicker.
There is a cancellor harness, made by some HID vendors that includes capacitors and resistors to get around this known problem.
The cheap HID kits don't have them.
Hope this is helpful?
Al.
Old Jul 18, 2009 | 04:01 AM
Twink's Avatar
Twink
its alright.. i found 2 relays in my house and the relays actually make the computer think there is something there so they work cherry...
Old Jul 18, 2009 | 10:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
20watt/10ohm resistors work. Radio shack part number 271-120 and $2.49 each
