AC issues?!?!?!?!
So one night...park my truck and everythings working perfectly. next day drive my beater truck into work and go to switch trucks after work to head to the girls house and....my AC will only work on HIGH. Works perfectly fine on high, blows cold, blows strong...but get NOTHING at all, not even the orange light above the AC button on the first 3 settings?!?!
So i'm thinking something with the switch but figure I could get some better input on here...
Thanks fellas...
Thanks fellas...
Lol I just noticed the same problem last night when I was sitting in line at the drive through at Taco bell and it was raining. I usually always just have my windows down, but I had the air on cuz they were taking forever, and it just didn't work at all unless it was on the highest setting.
Let me know if you figure it out man, cuz I had no idea what would cause that.
I take it I have to remove the dash to get to this circuit board? Or is there an easier way? Haven't removed the dash before so dunno who hard/easy it is yet...guess i'll be finding out!
Trending Topics
anyone know what the part is called exactly? The piece that is attached to the dash and that the **** slides onto. I tried searching rotary switch, rotary ****, ac switch, etc etc etc and couldn't find it to save my life...
Thanks.
Thanks.
It used to be that if your fan only worked on high it was the resistor pack. These were always known for going bad. It's usally stuck into the heater core box somewhere on the passenger side. I would look there first. I've had to replace them numerous times. Never really tried to see if it affected the A/C but I don't see why it wouldn't.
Had my blower resistor go out a month or so ago. You only get the AC on high. It is very simple to pull out and replace. Pull the plug, undo two screws, pull it out.
If you have a pull and save junkyard near by you can get the part for about 20 bucks. 60 or more new.
