Sound System Help...Underseat Subs
Old Jul 20, 2009 | 06:15 PM
hemipower05's Avatar
hemipower05
http://www.foxacoustics.com/ProductD...Code=DQC-210-S
so does this set-up just eliminate the metal fold out flappy thing? and this is the foxbox that you guys are talkin about right?
Old Jul 20, 2009 | 06:47 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by MAHUNA
Thanks for all the input, what I am looking at since a couple commented about it is getting the foxbox for 2- 12" and throwing in the alpine type-s 12"...they have a 5" mounting depth and the foxbox gives me 7"...any input?? anyone running the alpine type-s 12" subs?? also input on door speakers?? I was looking at pioneers just from a friends suggestion...
Alpine Type S will fit in the foxbox. If you have the power, I would get the Type R's. I'm pretty sure they will fit as well.
For door speakers....Did you read the middle of my last post??
Old Jul 20, 2009 | 07:32 PM
dodgenitto's Avatar
dodgenitto
Originally Posted by HoustonDodge
What I had done was the console between the 2 front seats I had taken out and a custom box made with 2 12s aiming downward and a space (hole, cubicle) at the top to put things and the original console lid put back on and the box wrapped in the same color carpet as my interior. I have 4wd and they even built around the shifter on the floor. The system will blow away many with 4 15s but you will pay for it...I would do it that way. Go to a place that does custom work and not just sell you a run of the mill box. Like I said it is more expensive but it will BOOM.
Originally Posted by 08DodgeTRX
Old Jul 20, 2009 | 09:15 PM
dirtydog's Avatar
dirtydog
Moderate User
^^^^^How is it worthless??? He's asking about fitment for now! I don't understand why anyone would needs pics to talk about specs?
Old Jul 20, 2009 | 09:58 PM
dodgenitto's Avatar
dodgenitto
It is in reference to HoustonDodge's response. He said he made a custom box for two subs where the middle counsel is. Just wanted to see what he had make??
Old Jul 20, 2009 | 10:43 PM
hemipower05
or does anyone have pics of their foxbox? that would b cool too....
Old Jul 23, 2009 | 04:36 AM
IowaHemi1's Avatar
IowaHemi1
Post I have alpine s series 12" sub in single box
This sub will fit in box for under rear seat. I wish i would have went with 2 subs though. It is hard to get good bass in such a small enclosure. I had a sony explode and the alpine hits way harder. I bought my box pretty cheap off ebay.
Old Jul 23, 2009 | 04:52 AM
Laramie1997's Avatar
Laramie1997
To the OP, what kind of music do you listen to? IMO, that should be 90% of your deciding factor. If you listen to country-classic rock- heavy metal- alternative, then you need to look at a 10" setup. Now, if your more pop, rap, or techno, then you want to look at 12"
