Squeel at 2200 RPM
Old Jul 20, 2009 | 06:16 PM
reel58's Avatar
reel58
Default Squeel at 2200 RPM
between 2200 and 2600 RPM I get a squeel or a whistle while accelerating at a full throttle exceleration it only happens for a moment. I checked the pully bearings and belt, it still makes the sound with the belt off. it sounds like its on the passenger side. it doesnt seem to affect the performance but its really annoying. Any thoughts?
Old Jul 20, 2009 | 06:20 PM
MontanaRAM's Avatar
MontanaRAM
air leak somewhere.
Old Jul 20, 2009 | 07:18 PM
reel58's Avatar
reel58
Thats what I was thinking, but what would open up at the rpm range? trans vacuum line?
Old Jul 20, 2009 | 09:23 PM
WhiteRam's Avatar
WhiteRam
Really high pitch whine/whistle?
Old Jul 20, 2009 | 09:24 PM
donjohnk's Avatar
donjohnk
you sure it aint your idler/tensioner pulley??? Mine did the same....
Old Jul 21, 2009 | 06:34 PM
reel58's Avatar
reel58
I changed the tensioner and a few idlers, only the PS and AC are un known, but I will try to take the belt off and try it again, just need a long straight away, to hard to turn the trun with out the PS hooked up.
Old Jul 21, 2009 | 06:38 PM
dirtydog's Avatar
dirtydog
Moderate User
Sounds like a PCV valve issue or crankcase breathing issue. My mustang made a similar noise like it was relieving air. The hose that went from the intake tube to the valve cover came off. i know it's a different car, but very similar issu'es goin on here.
