halfshaft replacement
Old Jul 22, 2009 | 04:15 PM
JohnnyZJ's Avatar
JohnnyZJ
Default halfshaft replacement
hi all. gonna tear into my halfshafts tomorrow seeing as the drivers one is pooched. any tips/suggestions on how to make this as painless as possible? thanks guys
trucks an 02' 5.9
cheers
Old Jul 22, 2009 | 11:45 PM
specialk77's Avatar
specialk77
good luck. let me know how you like the chicken**** retainer clip. the one that holds the cv shaft to the output shaft from the third member. got rid of mine 4 that ****-poor engineering.
Old Jul 28, 2009 | 02:24 PM
JohnnyZJ's Avatar
JohnnyZJ
wow. you sound angry about that issue! so theres a retainer clip holding it in eh? so remove clip, pull shaft out? sounds simple
Old Aug 1, 2009 | 01:16 AM
specialk77's Avatar
specialk77
just let me know how it turns out 4 you. im real curious.
Old Aug 31, 2009 | 01:02 AM
JohnnyZJ's Avatar
JohnnyZJ
so i just finished replacing the halfshaft. it wasn't bad at all. 3 hours or so. it was straight forward. pull the wheel, then the brakes. took the upper control arm off and the steering tie rod as well. at this point it was time to take the halfshaft out, and i've read lots of horror stories. this is not one of them. it slid off pretty easily. i used a screw driver actually. there is a little c clip on the axle which keeps the shaft in. i took it out. don't need it. so ya. it was easy............ my vibration on the highway went away!
