06-08 2wd suspension - same as 02-05?
Old Jul 22, 2009 | 11:07 PM
TXST8tj's Avatar
TXST8tj
Default 06-08 2wd suspension - same as 02-05?
most lift kits i am finding for a 2wd third gen only specify running from 02-05. Did something change in 06 that runs through 08 where the kits are different?
basically, i am looking for lift options for a 2007 2wd....leveling and lift.
Old Jul 22, 2009 | 11:10 PM
TRXHemi's Avatar
TRXHemi
They are different - keep looking as there are many lifts for 06-08.
I am not sure of the details of why they are different but I know they are.
Old Jul 23, 2009 | 08:38 AM
bigmac18's Avatar
bigmac18
Yep, they are different. Check out Fabtech or CST.
Old Jul 23, 2009 | 08:46 AM
Got_Hemi44's Avatar
Got_Hemi44
Are you wanting suspension or body?
You can run a 2" spacer with a 3" performance accessories body lift for a 5/3 lift
Or you can go to Fabtech and some other brands for a 6" suspension.
http://www.rockymountainsusp.com/dodge2wd.htm
Old Jul 23, 2009 | 12:10 PM
TXST8tj's Avatar
TXST8tj
well i've seen the CST kit (coils, spindles, blocks, etc) and it is for 02-08, so i'm just not sure where/how 06-08 is different if they offer one kit for 02-08 where the brake lines are the only thing they specify as being different on the 06-08. They also mention for the 02-05 models that they offer a different kit with a new upper control arms because the stock ball joint on those years does not hold up.
from what i can tell, 02-08 can all be lifted with coils, coil spacers, and/or spindles.
what is actually different between the two year ranges?
Old Jul 23, 2009 | 01:14 PM
bigmac18's Avatar
bigmac18
The upper control arms are different. The '06-'08 are larger and thicker, so some spacers cause them to hit the upper shock mount. Here is a picture of my front end setup with the Fabtech lift on.
Old Jul 23, 2009 | 02:10 PM
Ben D.'s Avatar
Ben D.
i think 02-05 used torsion bars instead of coil springs..?? but i'm not sure
Old Jul 23, 2009 | 05:02 PM
HemiLonestar's Avatar
HemiLonestar
They redesigned the front suspension and front frame for 06.
Old Jul 27, 2009 | 09:51 AM
bigmac18's Avatar
bigmac18
Only 02-05, 4x4's used the torsion bars, the 2wd's were springs.
Old Jul 27, 2009 | 10:44 AM
roadney's Avatar
roadney
do you think 06 upper control arms would fit on a 2002?
