Help with diffs.
Old Jul 24, 2009 | 08:51 PM
Bluesmanjesse's Avatar
Bluesmanjesse
You do have 2 filters on the tranny, there are 2 different styles also one for 2wd and one for 4wd.
Old Jul 24, 2009 | 09:08 PM
hifiwest's Avatar
hifiwest
Okay, so is one of the filters a twist on? Because if it is I'm looking in the wrong place...
Old Jul 24, 2009 | 10:50 PM
Bluesmanjesse
Ya I am pretty sure one should be a twist on.
Old Jul 25, 2009 | 02:16 AM
abarmby's Avatar
abarmby
One is a large flat pancake type filter. This filter does, as has previously been stated, come in two types. One for 4wd the other 2wd, so be careful which one you get.
The other filter is the "spin on" type, like your engine oil filter.
Hope this helps?
Al.
Old Jul 25, 2009 | 04:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, I was going to also say it looks just like an oil filter. Can miss it. However, to change the o-ring for the flat filter you will need a mechanics pick set (4pc for about $10) to reach up inside and pull the ring seal out.
Old Jul 25, 2009 | 12:10 PM
Redone4x4's Avatar
Redone4x4
Originally Posted by weedahoe
You must not be TOO old because your memory is correct and I agree with running synthetic. It doesnt cost that mich being you only need 3-4 qrts for the rear.
uh-oh, who said I was old in the first place??? haha
Old Jul 25, 2009 | 12:30 PM
SilverBullet08's Avatar
SilverBullet08
i did
Old Jul 25, 2009 | 12:49 PM
Redone4x4's Avatar
Redone4x4
haha figured as much. thanks homie.
