OEM style fog light kit?
Old Jul 23, 2009 | 09:51 PM
TheAlbinoRam's Avatar
TheAlbinoRam
Default OEM style fog light kit?
Anyone know where i can find a dodge fog light kit for a 06 1500 ST. that doesn't have them org. installed?
Old Jul 24, 2009 | 12:06 AM
Rojhan's Avatar
Rojhan
Keep in mind that since the truck wasn't built with fogs, you'll likely need to get the computer reprogrammed in order to be able to use the OEM fogs. Also, the headlamp switch will need to be replaced with one that supports fog lights as well.
I got mine on ebay from mopar4less. The kit included the lights and headlamp switch (and he was upfront about needing the programming).
Old Jul 24, 2009 | 12:13 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Look under the driverside bump and see if you're pre-wired for the fogs. There's two different kits you can get from the dealer....one for pre-wired trucks (comes with fogs, brackets, y-harness and new factory light switch) and one for non-wired trucks (fogs, brackets, different harness and a aftermarket style switch).
Old Jul 24, 2009 | 06:42 AM
fk1022's Avatar
fk1022
the dealer here charges $50 to reprogram the computer so the lights will work
Old Jul 24, 2009 | 08:46 AM
VP64's Avatar
VP64
i just bought some big round clear fog lights from kregans autopart store and used the original holder that they put in ur bumper. i cut up the lines on the holder and used the fog light bracket it came with and screwed it on onto the holder and put everything back inplace. they look pretty much oem. i have a toggle switch to turn them on but u can also tap into ur parking light's positive cable and addon an extra relay that way u can use ur factory headlight swtich
Old Jul 24, 2009 | 11:43 AM
R1mark's Avatar
R1mark
i also got mine off of ebay w/headlight switch but mine didn't need to be programed plus mine do stay on with the high beams
Old Jul 24, 2009 | 12:33 PM
fk1022's Avatar
fk1022
glad yours worked out of the box
Old Jul 24, 2009 | 12:59 PM
TRXHemi's Avatar
TRXHemi
The kit includes the switch etc.....and yes, the dealer will have to program the computer to tell it that there is fog lights. My dealer did not charge me though, and the fogs stay on with the highbeams.
Old Jul 25, 2009 | 04:16 PM
R1mark's Avatar
R1mark
i would hook everything up and see if it works before i would run to the dealer. it may also help to disconnect the battery when installing the fogs. if the wiring is there i would like to think that it should work out of the box like mine did, but maybe i just got lucky.
Old Aug 23, 2009 | 11:28 PM
Docwhitley's Avatar
Docwhitley
Default Sorry to have this bumped
GREAT NEWS!!!
I was riding down the street tonight and my dash started to fash bright then dull.... Hmmmm what could it be... Thought for a minute reached down touched the headlight switch... Bang first shot! So time for a repair, BUT REPAIR MEANS MOD!!!! YEAH!!!! I GET MY FOG LIGHTS!!!! And I do not need to argue with the wife about how she thinks I wont die with out them .
So I search and here is what I want to do... While changing the switch I want to add the fog lights in the bumper and/or Lights behind the grill.
Questions I have are ... How will I know if it is pre-wired for head lights? I am doing this because the head lights are horrible at night... Do you recommend behind the grill or factory position for those that have them... and last but not least... I do not want to drill into the frame so do you know of a bracket that will allow me to mount the lights behind the grill or should I try to fabricate one?
