Toyo Open Country M/T size?
Old Jul 25, 2009 | 09:39 PM
EJM05's Avatar
EJM05
Default Toyo Open Country M/T size?
Ok, heres the deal..... Im due for some new tires asap. I plan on buying the Toyo Open Country M/T. Heres the question now.... Can I buy these in the stock rim size? or do I have to buy a new set of aftermarket rims? I've read great reviews about the tire itself it you just have to keep it well maintained. So i've decided to go with those and thats my problem. I just need to know the tire size that will cause no rubbing at all. I don't want to deal with that ****.
Thanks in advanced.
-Erik
P.S. I tried looking in the search function but I came up short just found out other sizes and not what I personally was looking for. I have an ugly iron rim on the truck now cause my back left tire blew up on me on the highway. The steel belt broke within the tire. So I need to know the sizes asap. Sorry for the longs post.
Old Jul 25, 2009 | 09:53 PM
SMKNRAM's Avatar
SMKNRAM
looks like 33x12.50 is gonna be the closest to stock, same height just wider you may have to run spacers to clear suspension
Old Jul 25, 2009 | 09:55 PM
EJM05's Avatar
EJM05
Where to I buy spacers? Also, What size spacers?
Old Jul 25, 2009 | 09:57 PM
SMKNRAM's Avatar
SMKNRAM
ebay cheapest around make sure they are hub centric, and 1.5 inch bolt on spacer
Old Jul 25, 2009 | 10:01 PM
EJM05's Avatar
EJM05
Is there another place to buy? I dont trust ebay ever. I know a ton of people buy on ebay, but for some reason i dont. like a couple more $$ aint going to kill me.
Old Jul 25, 2009 | 10:03 PM
SilverBullet08's Avatar
SilverBullet08
i wouldnt run spacers just for tires...
Old Jul 25, 2009 | 10:07 PM
EJM05's Avatar
EJM05
So do i just let it rub? or is there a possibility that i can get the tire less wider. I just want the stock size, meaning height and width, just with a new brand tire.
Old Jul 26, 2009 | 08:28 AM
SMKNRAM's Avatar
SMKNRAM
you can do it with another tire, but if you want that toyo it will rub. And there are alot of guys running spacers without issue! It is no different than getting an offset rim and wide tires, same wear and tear on parts. just my .02
Old Jul 26, 2009 | 12:34 PM
kicker417's Avatar
kicker417
if u run 33,12.50,20 you wont need no spacers at all but if u run 35,12.50,20 you will need spacers. Ps i had 325,60,20 with out a leveling kit.
Old Jul 27, 2009 | 01:42 AM
EJM05's Avatar
EJM05
so with out a leveling kit i can buy 33,12.50,20?? i think im just going to buy a 2.5in leveling kit. so then it will just fit fine with no problems. if i go that way then i wont need spacers right?
