Lowered Trucks: tech and info....
Old Apr 22, 2010 | 12:25 PM
  #1151
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by Shiloh 24
Could I put in helper airbags after I remove the overload to prevent any problems from happening? Also if I decide later on to go to a more extreme drop like the 2/4.5 that Okla suggested in my thread could I use the bags in conjunction with that kit?
Certainly, Helper bags is the solution when lowered and you still need to haul loads.
Old Apr 23, 2010 | 04:25 PM
  #1152
Got_Hemi44's Avatar
Got_Hemi44
Anyone running belltech drop 2 shocks and know if they'll work on a 4x4? Everywhere I've seen them listed says 2wd but i don't see a reason the rear of a 4x4 is any different. Other thing is i already have 2" drop shackles on the truck. With drop 2 shocks will they work alright with shorter shackles and allow for 4" of drop? My truck being a 4x4 seems to through a wrench in every time i look at suspension modifications.
Drop shackles lowered the rear 2" but it's still not level with the front. Looking to get another 2"-3" of drop without a flip kit.
Old Apr 23, 2010 | 07:09 PM
  #1153
HemiKris's Avatar
HemiKris
so i lowered my truck 2 inchs in the front and 4.5 in the back. Now the rear is bottoming out all the time so I'm gonna go get some belltech nitro drop shock 2's and was wondering where i could buy some after market bump stops
Old Apr 23, 2010 | 07:41 PM
  #1154
RedTruck-VA
I just got these:
http://www.jegs.com/p/Prothane/Proth...62170/10002/-1
It is not a direct bolt on as the holes need to be lenghtened. Maybe I'll get mine mounted tomorrow. Good luck
Old Apr 23, 2010 | 07:51 PM
  #1155
HemiKris's Avatar
HemiKris
i was also thinkin bout getting some helper bags too but can you ride around with the inflated just a little bit all the time to help out the ride?
Old Apr 23, 2010 | 07:53 PM
  #1156
Shiloh 24's Avatar
Shiloh 24
I don't see a problem with having a couple PSI in it full time, it isn't gonna help though only make it stiffer.
Old Apr 23, 2010 | 08:02 PM
  #1157
RedTruck-VA
Got_Hemi44, first, you got my vote. When I was using drop shackle I measured the travel between the axle and bump stop and then measured the mounted shock to help determine the shock length that would work on my truck. Once I determined the closed length and the extended length I went to the Monroe shock chart and selected the shock type and selected the shock that fit my application. http://www.monroe.com/catalog/docume...engthSheet.pdf
With this information you can go to any auto parts store and cross reference the shock to other brands if you don't like Monroe. I have a flip kit installed now and the monroes I bought still properly fit without using extenders. I would go a head and install the flip kit and then use shackles to raise the rear to the level you want. It is the simplest and cheapest way to get what you are after if I understand you correctly. Good Luck...
Old Apr 23, 2010 | 09:16 PM
  #1158
BadHab1t's Avatar
BadHab1t
raw ram you are dead wrong you wont be level with just drop shackles, and i haul stuff all the time and i have no issues without a o/leaf...between my 2" drops and no o/l i am dead level but i also plan a 2/4 later this summer...shock extenders are only needed if you dont wanna use drop shocks....got hemi im not sure you are gonna find something with out doing a flip you could always do the flip and buy longer shackles....and btw good luck in otm you got mine....love the street trucks....
Old Apr 23, 2010 | 09:41 PM
  #1159
rbeard79's Avatar
rbeard79
Dropping the truck tomorrow!!!!! Cannot wait. Got Belltech Nitro Drop 2 shaocks for all around with a McGaughy's drop kit, but Belltech drop shackles!! Gonna go for a 2/5 if I can since I have different holes I can use with the Belltech shackles. Will get pics if it is not storming too bad tomorrow!!!
Old Apr 23, 2010 | 10:10 PM
  #1160
RedTruck-VA
You are going to like it....
