Lowered Trucks: tech and info....
Old Jun 6, 2010 | 08:50 PM
  #1271
truckin151's Avatar
truckin151
The mcgaughy kit is a 2/4.5" drop right? Looking at the ad, it looks like it comes with both the drop shackels and a flip kit, is that right?
Kit Includes:
Front Coil Springs
Rear Flip Kit
Rear Shackles
Rear Shock Extenders
Rear Bump Stops
Vehicle Applications:
2002 - 2005 Dodge Ram 1500 Std Cab 2WD
For the price I think I'd rather do that rout instead. azskater - did you get your kit from that street pro's site?
Old Jun 6, 2010 | 08:56 PM
  #1272
SilverBullet08's Avatar
SilverBullet08
here ya go truckin
http://www.timssuspensiononline.com/MCGAUGHYSDODGE.html
Old Jun 7, 2010 | 12:53 AM
  #1273
Desert_Ram's Avatar
Desert_Ram
yes i did that same kit came with everything needed and very fast shiping when it went out got it in 2 days and they gave me the tracking # right away great guys to order from, very easy to install took me a little longer due to i was by myself when i put it on but it is a wonderful kit imo! let me know if you have any other ?'s
Old Jun 7, 2010 | 12:56 AM
  #1274
Desert_Ram's Avatar
Desert_Ram
oh and yes the kit is a 2/4.5 drop
Old Jun 7, 2010 | 09:34 AM
  #1275
truckin151's Avatar
truckin151
So your truck sits pretty much level then or does the bed sit a little lower with the 4.5 drop?
Also, I know on certain kits you can raise the rear a little to give it a slight rake, can you do that with this kit? Having it level is nice and all but I would like to have mine with a slight rake to it.
By the time all is said and done this is how I want it to look (which I believe is the 2/4 drop since the SRT-10 has the rear flip kit)
Old Jun 7, 2010 | 02:48 PM
  #1276
Desert_Ram's Avatar
Desert_Ram
yes my truck sits pretty level but on the rear shackles that come in the kit there are to adjustment holes that the leaf pack will bolt in a upper and lower i have mine in the upper so i avoid the rake i personally cant stand the rake but if that is what you like it will still comply with what you want as-well buy simply just bolting in the lower hole!
Old Jun 7, 2010 | 02:55 PM
  #1277
Desert_Ram's Avatar
Desert_Ram
as far as the height goes im at 33" front and back from ground to wheel-well or (bottom of fender) hope this helps!!!
Old Jun 7, 2010 | 04:03 PM
  #1278
BadHab1t's Avatar
BadHab1t
for 350 to the door thats a great price....
Old Jun 7, 2010 | 05:34 PM
  #1279
Nekko's Avatar
Nekko
I have a question AZskater, Should I replace my shocks before or after the drop. Or will it be ok with stock. I assume that I would need to remove my running boards ?
Well more than one question Thanks in Advance.
Old Jun 7, 2010 | 06:20 PM
  #1280
Desert_Ram's Avatar
Desert_Ram
okay well to start off im still running my stock shocks front and rear im waiting for a few extra bucks to order belltechs but u will be fine running your stocks as long as u use the shock extenders for the rear and after the drop not before the rears will be to short at stock height!
and no i wouldnt thing you would need to remove your running boards but imo it would look better with out them just my .02
and jay it really is not a bad deal they are very honest and nice guys they were the ones i ordered my roll pan though but it didnt come from them it came from there warehouse somewhere else cause they were on back order and if you remember it had a little ding in it when i got it and i told them and they sent me a new one out the same day overnight and gave me a killer price on the lowering kit great people will recommend them!
