Lowered Trucks: tech and info....
Old Aug 24, 2010 | 11:55 PM
  #1511
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by ricofv
i lowered my truck the otherday ... hit a damn semi tread on interstate yest . on my way home from wal-mart today heard an cliclin noise. stopped in a parkin lot down the street and felt the rearend shift ... drove it home slow and could feel the vibration .
rear end shifted up .. drive shaft angle is almost "0" ... so goin to loosen the u bolts up and turn axle..
anyone know the angle degree for the drive shaft ?
Rico,
This has been reported to have happened on occassion with flip kits especially when hard launches have been done. The recommended fix is to spot weld the spring perch to the axle housing. I welded mine when I first did the drop. As for proper angle, basically line the pinion angle so that it is parallel to the the trans angle, the two lines must be parallel. What I am poorly trying to discribe is the pinion axis is parallel to the trans axis. Hope that helps. Good luck...
Old Aug 25, 2010 | 09:26 AM
  #1512
Atwiss's Avatar
Atwiss
so i was looking at the moes performance 2inch drop what do i all need to accomplish the full 2inches do i need to remove the overload spring or replace it
Old Aug 25, 2010 | 12:13 PM
  #1513
mdeniz's Avatar
mdeniz
Anyone with the belltech drop kit, did you need a spring compressor for it? I never done one of these trucks and I don't want to go rent one if i don't have to, in cars you normally can get away with out using one since the spring is a bit smaller.
Old Aug 25, 2010 | 04:38 PM
  #1514
BadHab1t's Avatar
BadHab1t
tx hemi check out my exhaust thread in the tech section for help id really appreciate it....
Old Aug 25, 2010 | 07:29 PM
  #1515
BadHab1t's Avatar
BadHab1t
Originally Posted by TXhemi5.7
txhemi where did you get these tips were they just what the exhaust shop had? what they charge you to dump it....
Old Aug 25, 2010 | 07:54 PM
  #1516
TXhemi5.7's Avatar
TXhemi5.7
Whats up boss? u see my new headlights?
to answer ur questions...i had an exhaust shop bend 2 1/4 pipe then just cut it like that, and i was only charged $40 to cut my old pipes off, make the new ones, and weld them on. I did it for the time being til i do my custom exhaust. Hope this helps man ill go look at ur thread too
Old Aug 29, 2010 | 08:13 PM
  #1517
mptoad's Avatar
mptoad
What shocks should I use on my 07 4.7 4x4 QC SLT? I am installing drop shackles soon and want to do shocks at the same time. I am tired of the back end jumping all over the place when i hit small bumps while accelerating... Everybody has said new shocks, instead of the cheap ones dodge uses should fix this... so what brands? Belltech or bilstien?
Old Aug 31, 2010 | 10:09 AM
  #1518
tuned93's Avatar
tuned93
mdeniz: if your talking about replacing the front springs, i dont think you "need" them, if i remember correctly when i dropped my truck i just removed the upper control arm and pushed down on the lower and had a buddy pull the spring out. although IMO it would be alot easier with a set of compressors. you can rent them at Auto Zone and when you return them you will get your money back.
mptoad: you can really use any type of aftermarket shock to keep your rear end from hopping around. both although Belltech or Bilstien are great companies, their stuff is a little on the expencive side. but if you have the money, by all means... but on the other hand, you could look into a set on Monroe's or just see what your local auto parts store has in stock. any new shock is better than a crappy old factory shock. and since your only doing shackles.. you dont have to get a smaller shock.
welp.. i've made up my mind... again. im (still) gonna bag my truck. ive researched a bunch of different 'sites with different bag kits. some with everything and some with most of the stuff. ive decided i want to get a kit with everything included. (so that narrows things down a bit), i just need opinions as to what the "best" kit is... the options are as follows:
- FULL SIZE Truck EXTREME Air Suspension Kit With 4 Links, Panhard Bar & Frame Bridge
http://www.x2industries.com/chassist...dge-p-347.html
- 8-VALVE RidinLow Customs AIR BAG KIT WITH NOTCH & 4-LINK
http://www.ridinlowcustoms.com/8valv...ng-p-3741.html
^^^ ...same thing, different site... v v v
- :: 8-VALVE AVS AIR BAG KIT WITH NOTCH & 4-LINK
http://www.avsontheweb.com/product.p...505&bestseller
- FBSS Airride Bagged Suspension Kit 2002-2006 Dodge Ram 1500 F=BAG/BRK, PARALLEL 4LINK
http://www.airbagit.com/product-p/fbs-dod-56-kit5.htm
so out of these 4 kits... which one do you think is the best "bang for the buck"? keep in mind im also trying to stay below 2 Grand... so thats why i chose these particular kits.
Old Aug 31, 2010 | 10:27 AM
  #1519
mdeniz's Avatar
mdeniz
Thanks for the tip, i actually did it over the weekend by my self with out the compressor, would of been nice with another set of hands for sure....Now i need to do the rear but i dont have the right tools at home yet so i may do it over the weekend at my buddys house.
Old Aug 31, 2010 | 12:39 PM
  #1520
tuned93's Avatar
tuned93
you doing a flip kit?
