Lowered Trucks: tech and info....
Old Apr 16, 2012 | 09:14 PM
  #1761
thumperk15's Avatar
thumperk15
With that said I'm lowered 2/4.5 on 24's and low pros and I haul lumber, home remodeling stuff, and a 16ft trailer with a 4,000-5,000lb truck on it a lot. Unless you're 4/6 you'll be fine hauling whatever.
Old Apr 18, 2012 | 12:11 PM
  #1762
ibar's Avatar
ibar
Default i want to lower my 96 dodge dakota cuz i cant lift it
i dont have the money for lowering springs i was thinking of cutting them an getting a lowering block kit for the rear leaf springs can some one help me out with the process of cutting the springs like how much do i have to cut to get 3 inch drop and how i should go about doing this??
Old Apr 18, 2012 | 01:02 PM
  #1763
thumperk15's Avatar
thumperk15
Rams need a flip kit, blocks will raise it u, leafs on bottom on them. Normally if you cut a half wrap you get an inch. If you want 3in it should be a 1.5 wraps of coil. Others may know more about this but that's usually how it goes.
Old Apr 19, 2012 | 08:47 AM
  #1764
ibar's Avatar
ibar
my truck the leaf springs are under the the axle so wat i was thining is if i just put the blocks inbetween the springs an the axle would that work an a wrap on the coil is that a whole spiral of the coil?
Old Apr 19, 2012 | 09:11 AM
  #1765
thumperk15's Avatar
thumperk15
My bad, I thought you had a Ram. You're in Ram tech forums man lol. Now that Dakota disregard everything I said. Now for a full wrap you should obtain about a 2in drop. If you go over 2in block on the rear get some angle cut block to correct the axle. Remember to chain the coils in while removing them!
Old Apr 23, 2012 | 09:04 PM
  #1766
BadHab1t's Avatar
BadHab1t
Originally Posted by jek_ns
Hey guys I need some help. I have a 1500 quad cab that i bought already lowered. it was lowered using DJM's flip kit with adjustable shackles. I want to raise it up a little because i'm going to be hauling some stuff around. The previous owner told me it was really easy to adjust the shackle position and i could do it with as little as 2 jacks, a wrench and a socket. I know messing with springs can be really dangerous so i don't want to go at it without any idea of how to do it. can anyone do a quick write up for me please? or at least tell me where is the best place to put the jacks/jack stands?
Thanks.
adjusting shackles is easy, no harm involved, jack the truck up a little at a time using a jack on the hitch, watch your shackles when they look like they have the load off, remove nuts and bolts, then jack higher to desired hole replace bolts and nuts...drop truck and go...real easy...
Old May 25, 2012 | 10:38 AM
  #1767
dk88's Avatar
dk88
Well I guess you heard this question often, but maybe you can help me.
Third Generation 1500 Ram Single Cab 4x4.
What you would have to pay for an airbag suspension?
How many inches are between the lowest and highest position?
Idea is not that bad, if you wanna park you lay the truck nearly on the ground, and while driving you pump it up. Dont know what you could get out of these airbag supensions though.
Well layin on the ground is a bit rough. at a certain point you would have to make cutouts for the backwheels.
lets say I want the ram to go down by circa 7-8 inches if possible - mainly for parking. is it possible to drive this low without working on the wheel arches and stuff?
Old Jun 16, 2012 | 05:36 PM
  #1768
Dhawk2013's Avatar
Dhawk2013
New Member
I have a 2003 dodge ram with a 6/7 drop on 20's. is there any way i can go to 22's?
Old Jun 16, 2012 | 11:04 PM
  #1769
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sure, just get skinnier tires.
Old Jun 27, 2012 | 01:29 PM
  #1770
uberdude209's Avatar
uberdude209
im looking to level mine its a 07 2x4 single cab..where and how do i go about doing this..and what am i looking at cost wise
