3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
hey guys, you never gave me those measurments from your truck. i wanted to compare the fender heights of our trucks to see whos is lower. measuring from the ground to the fender center the hub my front is: 32.25'' and the rear is: 32''... whatchya got?
Ok, Stylintrucks had there 4/6 kit for $680 plus whatever shipping is on that. If I got that pricey I'd just bag it, simple as that. That's C-notch and 2in coils also. Is there a 3in spindle option for my 2008 quad, or would that be a 1in coil I that kit?
I haven't found a 3/5? Can anyone get me a good price on a 3/5 kit, with spindles possibly but i'd do a 3in coil, rather not though.
thats what i was thinkin, even though runnin 22's with the same drop if not lower... you'd be sitting higher due to the bigger wheels. im just tryin to see whos got the lower stance from us dropped fullsize guys
Whomever is asking about a 4/6 drop, this can be achieved by buying the 2/4 drop and a set of 2 inch drop spindles. If you do like I did today, and use the factory shackles, you end up with a 6 inch drop in the rear. To get your 4 inch in the front you will use the 2 inch drop springs and 2 inch drop spindles. Just an FYI.
I am 30" all round, but i am running 275/55/17's on a 4/6.
