fluid on garage floor
Old Jul 28, 2009 | 11:51 AM
Man in Blue's Avatar
Man in Blue
Default fluid on garage floor
what would be leaking from the front end. Looks like its coming from CV boots???? couple drops per day. I know nothing about repairs. If it is something serious would it be under warranty, 2006 31K?
Old Jul 28, 2009 | 11:56 AM
dirtydog's Avatar
dirtydog
Moderate User
Power steering fluid. You prob need a new Rack & Pinion or new boots
Old Jul 28, 2009 | 12:08 PM
Jason D's Avatar
Jason D
The shocks/struts are notorious for leaking.
Old Jul 29, 2009 | 09:44 AM
Man in Blue
Shocks and struts? what is leaking, does it stop, do I replace them or what. ?
Old Jul 29, 2009 | 11:51 AM
Jason D's Avatar
Jason D
My truck only has 4000 miles on it so mine havent started leaking yet. I heard that they would be waranteed, but I also heard that they had so many to replace that they have been on backorder for months now.
Old Jul 29, 2009 | 02:58 PM
abarmby's Avatar
abarmby
Sorry bud. But if you don't know even this level of simple mechanics, please take the truck to the dealers for help/repairs.
Please don't think I'm having a pop at you.
You need a certain level of mechanical experience just to start things off.
Which from your post and you openly admit, you haven't got.
Take care and good luck.
AL.
Old Jul 29, 2009 | 05:48 PM
Tazman40's Avatar
Tazman40
My 06 just had the struts repaced last month with 20k miles on them.Its a known problem.Crawl under the truck and just look around and see if you can find anything wet.At least that will get you in the general area of the leak.Could be anything from struts to antifreeze to a oil pan gasket,power steering fluid,trans cooler line,brake line etc.If its four wheel drive it could be a front diffrential seal.Theres alot of things under there that can leak. If you cant find it take it to a reputable shop that you trust that wont just B.S. you and take your money replaceing parts that dont need replaceing.
Good luck and i hope its a easy cheap fix.
Old Jul 29, 2009 | 09:47 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
What color is the fluid? If it's redish it's probably the power steering like dirtydog said....dodge uses tranny fluid in their PS.
